Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: Relocate Toilet - Solid Slab Foundation
    DIY Junior Member florida_wen's Avatar
    Aug 2005
    Plant City, Florida
    Unhappy Relocate Toilet - Solid Slab Foundation
    I live in Florida where most homes are built on solid poured concrete slabs, and pipes are installed prior to this pouring. We just moved into a 1989 home in great condition with great views of a beautiful pond behind, but it has two small bathrooms. I have NO problem with removing and installing new walls, as many of my relatives are builders up north (Connecticut, Mass.) and I have experience with this. The "problem" comes with having to relocate the DWV for the toilet about five feet from where it currently is. I am going to re-tile the floor, but to "move" and re-install the trap and flange would obviously require quite a bit of cutting, chopping, and repouring a channel in the concrete slab floor. Am I a "fool" for even thinking of doing this ?? Am I opening up a big, big can of worms ?? Most of my life, with every project I started, I have always "first thought" it would be easy, cut and dry, only to have them blossom to the point of extreme frustration.
    DIY Senior Member thezster's Avatar
    Jul 2005
    Fort Collins, Colorado
    Just finished doing the same thing - for the first time. It wasn't all that bad - but was a lot of work.
    Make sure you know which direction the underground drain from the present toilet runs. Nothing more frustrating that cutting a hole and not finding the sewer line.
    Plan on lots of dust from scoring the present concrete - and smell to permeate the house for a day or so --
    I'm sure you'll get more advice from other "more qualified" people on this site... they've been invaluable to me.
    alhurley
    Guest
    Quote Originally Posted by florida_wen
    ....Most of my life, with every project I started, I have always "first thought" it would be easy, cut and dry, only to have them blossom to the point of extreme frustration.
    and your point is????
    the answer is "it depends." Largely it depends on where the new toilet will sit in relation to the old location. Is it moving along the same line as the existing drain (ie, you would shorten or lengthen the existing drain)? Or is this going to require a new run to the stack? Remember you want to keep the drain as straight as possible. And don't forget about the slope- if you (for example) are extending the current drain by 5' and there is a 1/4" per foot slope (is that right?) the new toilet flange would be 1-1/4" higher than the old one. Problem? you'll have to answer that one.
    so like I said, "it depends."
    Feb 2005
    Talking yes you can
    you can really get yourself into a mess moving
    a pipe in a slab home....
    if the heat runs are in the floor, they could be in the way
    their could be water lines in the way too...
    it really depends on how much you desire to do this move...
    just about anything can be accomplished with some hard work
    and a littte luck...
    so it all depends on how lucky you are...
    look at the mess I got myself into on my own personal project.....
    scoll down to the bottom of this web page...
    and see all the pipes I found in the way
    http://www.weilhammerplumbing.com/services/
    Aug 2005
    Plant City, Florida
    Unhappy yes I fully understand.....
    .... the extreme amount of difficulty and frustration a project like this can be. Luckily I am only moving the toilet about three feet from the original location, but more at the "end of the line" so to speak, so this new drain/waste pipe will actually be "higher" in pitch. Unfortunately this toilet relocation is the ONLY necessary evil to do to enable us to expand our very small Master Bathroom, presently 5 feet wide by about 11 feet long, into a new spacious, 11 foot wide by 16 foot long master bathroom, that will then have two nice large windows. I actually plan to remove a wall that presently separates the master bathroom from our very small dining room and eliminate the dining room altogether. We have a large eat-in-kitchen so we won't miss the dining room at all. The darn toilet is just in the "middle" of everything, and believe me, if I didn't have to move it I certainly wouldn't. I wish I had some "as-built" plans for this 1989 house or at very least a sketch of the DWV lines. Being very observant to many Florida slab constructed homes, I can almost tell where the drain line in our newly purchased home runs, but obviously it may have a slightly different path.
    This "older" (1989) home actually has carpet in both bathrooms so once I tear it up, the raw slab is easily exposed. I was wondering if a Plumber can come over and actually "trace" the route of this drain pipe with a "meter" of some sorts.... something that follows water like the "call before you dig" people do?
    Feb 2005
    Talking just do it
    if you are only going 3 feet
    it honestly does not have to have any fall at all.
    it will work fine even if it is running totally level
    all the way . dont worry about it...
    Aug 2005
    Plant City, Florida
    Question this may sound "dumb"........
    ........ but are there any "publications" or "guides" to properly instruct me in cutting into the slab so I won't crack it. I'm sure there is no water pipes and no re-bar where I will be cutting and hopefully no wire mesh under there. I have used water cooled, portable circular tile saws as well as masonary blades in standard circular saws many times before. In fact I spent four months (three years ago) constructing a Versa-Lok (split-face) stone wall (about 80 feet long by 5 feet high) and learned quite a bit about cutting, drilling and "splitting" concrete products. Should I invest in a good (used) "hammer-drill" or "air powered chisel" to actually break-out the concrete ?? Or just the old 20 pound hammer and 2" hand chisel ??
    alhurley
    Guest
    why in the world would you buy a hammer when you can rent it for a few bucks? I know, I've occasionally purchased the big-ticket tools and resold later, but that was where I needed the tool for many days and rental fees got exhorbitant. You only need this thing for a day at most, especially if you do the saw thing first. My local Homer rented me an almost new Hilti 505 last week for less than 50 bucks for overnight (picked up at 6pm, returned by 9am). those things start at $1000 and go up quickly.
    Jul 2005
    Having just completed the same type project - I can tell you what worked for me...
    Used a circular saw with masonry blades ( 10 blades for a 25 X 30 hole). Score the outline as deep as you can - I found 1 inch to be adaquate for a clean score on breakup. On one corner of the proposed cutout I went deeper - about 3 inches - and made a triangular cut big enough for the head of my sledge hammere. Once done with that I knocked out the triangle with a few good blows. Once that was out, I dug sand/gravel out from under the remaining portion of the cutout (to give the concrete some "give"). After that it was hammering/diigging/hammering/digging until my cutout was done. My 25 X 30 hole took about 3 hours and a bit of sweat. But all in all - not too bad. The only place I used a chisel was working close to the main stack (PVC). Other than that - a 9lb sledge did all the work.
    The masonry blades kicked off tons of dust and the smell permeated the house for a full day.
    Also - while I thought I knew intuitively which direction the main drain went - turns out I was wrong. Luckily my hole was big enough to reach it. Give yourself plenty of working room (make the cutout big enough to dig/cut and glue pipe/etc. Making it large enough now will save making it bigger later. You're only talking a couple more bags of Sacrete in the end.
    Good luck... and stock up on some Ben-Gay
    Aug 2005
    Plant City, Florida
    Red face You're 100% correct.......
    ....... I guess was thinking of a "small" hand held hammer drill, purchased used for like $75 - $100, something like the auto body shops used to cut steel. I'm sure that what alhurley is describing (Hilti 505) is ceratainly the professional (and easiest) way to go !! And YES, HD is okay for "tool rentals" too !!
    Aug 2005
    Plant City, Florida
    Smile thezster - got any pictures ????
    I would love to actually see some pictures. I'm a "nut" with the digital camera, photograph everything I do !!
    I happen to find the following on a D.I.Y. forum:
    As to finding an under slab line, contact a plumbing company that has a
    SeeSnake with the locator accessory. It is a sewer line camera that the
    locator can follow. There are other locators such as SubSite (by
    DitchWitch) that can follow a beacon. They can usually also work
    following a signal induced on a sewer maching cable.
    You can sometimes get fairly close by following clues given by givens
    such as clean outs, vent stacks, floor drains.
    I know that currently here in this part of Florida they use that "greenish colored" 4" drain pipe, but I wonder exactly what drain pipe they used here back in 1989? I haven't removed the toilet yet, but I'm sure that will be the surest way to tell
    Last edited by florida_wen; 08-16-2005 at 04:26 AM. Reason: added more info - why make another reply?
    Jul 2005
    See my post "Would appreciate professional critique before inspection time" and also "More critique please" - located on this forum. Note the main drain comes off the stack at a 45 degree angle from the wall. I was expecting it to parallel the wall as the city sewer is actually "behind" the project area.
    Of course, if you're moving an existing toilet, your "guestimate" will be easier. Start at the toilet stub - cutting out at least a foot in all directions (allowing cutting/glueing work).... then continue your cut to your new location. Be careful knocking concrete around the existing drain (that's where the chisel comes in - you don't want to shatter it to pieces - then again, you're going to take it out anyway so you don't need to preserve it...... then again, why take chances cracking the drain line....?
    I wanted a pro's opinion of my plumbing work.....
    Feb 2005
    Talking small sledje hammer and a large chisel
    sometimes you just got to get
    Mid -evil on that floor and just use something
    to beat the hell out of it....
    a simple small or large sledje hammer and chisel sometimes
    is the best way to go about work like this
    you beat a small hole "Probe hole" through the concrete probably where
    you want the new toilet to go then widen the hole
    looking for trouble , then beat and dig work your way back
    to the toilet location digging and widening the hole as needed..
    cutting through someting with a saw is not good...
    but chipping away at the floor with the chisel and sledje
    you will discover all sorts of pleasent surprises without doing
    major damage
    DIY Senior Member MG's Avatar
    Jun 2005
    Illinois - Near St. Louis
    I wish our main bathroom was "very small" like that. Its 5'x8'. The 2nd bathroom is smaller than that.
    Removing a room in a house is not good for resale value IMO...
    Jul 2005
    IMO it depends on the house... In this day and time, a large - well done master bath is a huge selling point. Having numerous tiny rooms is "claustrophobic"........
