Results 1 to 5 of 5
Thread: too much is going wrong!
    DIY Junior Member amw04004's Avatar
    Sep 2009
    Arkansas
    Default too much is going wrong!
    Hi, first of all we have a septic system. I don't know if this could possibly be part of the problem or not but I do find it strange that we are having all kinds of plumbing issues that are seemingly unrelated...
    First, we have a double kitchen sink that has always worked fine... now all of a sudden it doesn't want to drain, so thinking it just needs the disposal to be ran, you turn it on and all kinds of nastiness pops up in the other side of the sink.
    Second, our bathtub refuses to drain, no amount of drain-o or snakes or whatever will make it drain.
    Is there anything I can do, or are we just going to have to call a plumber?
    Jul 2008
    S. Maine
    Call the guy that pumps your septic tank.
    Nov 2006
    Quote Originally Posted by amw04004 View Post
    we have a septic system ...
    we have a double kitchen sink that ... doesn't want to drain ...
    Second, our bathtub refuses to drain ...
    Since you have not mentioned any toilet troubles, I would guess you need to clean the trap under the kitchen sink and have someone come clear the drain line for the tub ... and be sure to let him or her know about any and all chemicals you have already tried!
    Default drains
    Unless your sink has an AAV instead of a vent out the roof, ANY septic problem would not cause your symptoms. IF it were a septic problem the sink WOULD drain, but the water would come up in the bathtub or shower, and your toilet would not flush. You need a plumber to snake the drains and get them flowing properly again.
    Jul 2008
    S. Maine
    We should start a company pool on these things just for fun.
    I'm still betting on a full septic. I know, the toilet issue, but I done seen this a lot of times. My house in fact. For some strange reason, my toilet will flush and the regular drains won't when the tank's full. Oh, hell, the OP will probably never post what he found anyway.
