dwl
- Messages
- 5
- Reaction score
- 0
- Points
- 0
I have a 19 year old model 100 system (white tanks). I'm getting rusty water from both tanks. I have emptyed the brine tank of salt and cleaned the brine tank. I have also mixed res-up in a bucket with the brine pickup valve and cycled it through both tanks. Water was pulled in and bucket refilled but has not helped the rusty water problem. There is rusty water around the gear in the sight cover, so much that you can't see the pawl's. I'm wanting to take the head apart and check for a plugged hole or stuck valve or maybe a stripped turbine gear that I've heard of on these forums. I had it apart about 10 years ago when 1 tank stopped regenerating and found a rust flack in one of the pin holes, but I can't remember how it came apart. Should I remove it from the tank or just disassemble it on the tank. I was worried the pickup tube might come up with the head and let resin under it. Does anyone have a parts break down of this head or some pictures of what I need to look for and where I can buy parts. Also should the resin media be changed after 19 years of service on well water? Thanks Dennis
