Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: Wet Venting, Plumber Made Mistake, Opinions
    DIY Junior Member arejayesss's Avatar
    Aug 2009
    SW Florida
    Default Wet Venting, Plumber Made Mistake, Opinions
    Hello all,
    As you can can see this is my first post on this forum. I have lurked like others do for a while. I was really hoping to just read others problems and not have to post about my own. But, alas, I have a doozy (I think) I have found out from a plumbing expert that there are issues with the way my DWV lines were setup in our new master bath remodel. I hired a professional to ensure it would be done correctly. Enough talking though, let me post a few pics so you can see what I'm dealing with.
    I was hoping to get some second opinions if possible. Any advice on how to pursue this situation would be great. PS the inspector signed off on this, and it has since been covered with concrete and framed walls. Luckily we haven't finished the bathroom yet.
    Thanks in advance
    Plumbing Contractor C NUMB's Avatar
    Jan 2009
    NPR, FL
    Whats wrong with it?? Looks alright to me.
    Is there a lav on each of those stacks??
    I'd Rather Be FISHIN'
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    I agree with C NUMB, it generally looks fine to me...unless you don't plan on continuing up the vent stack up for that lav sink, and I hope you don't plan on discharging anything into that 3" line from above other than a sink.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Jul 2008
    S. Maine
    It's plumbed to code.
    Apr 2005
    In KY that would all get torn out.
    No flat venting
    Every fixture must have a vent, and those don't.
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    The only thing that I see in the 1st pic, is that your floor drains are not vented properly. The same issue that dunbar plumbing is suggesting
    Otherwise it would be fine
    Aug 2009
    SW Florida
    Quote Originally Posted by C NUMB View Post
    The 2" stack has a lav. The 3" has a washing machine discharge(other side of that wet wall, you can see the outlines on the bottom right for W and D)
    Quote Originally Posted by Basement_Lurker View Post
    Thats part of the problem. I was actually informed that 1. On the bathroom group, only bathroom fixtures can be used (Which now makes sense to me) Washing machine cannot be put into that 3" stack. 2. The shower drain (First picture, left foreground) does not connect above the 3" elbow to wash it out. These are things I am now learning about. I will have to contact the plumber in the morning and have a little discussion. Both of these issues are code violations that the inspector also missed. I was referred to the code 909.1 and also Florida Residential Code P3108 which both basically say the same thing. Either way, I might be out of luck. I will try to get it rectified. Thanks for your input. Time and time again, I have found this forum to answer all my questions and then some. I really do appreciate your efforts and I have a new found respect for you guys
    Dec 2005
    SW Florida
    In Florida, the only problem you have is the washing machine as part of your wet vent. I still haven't heard the reasoning behind that part of the code to where it would make sense, it'll work fine and in fact a couple of codes back you would be OK.
    If your inspector signed off and the concrete is in I wouldn't sweat about anything you have there.
    Where are you located? I'm in the Cape and work in Ft Myers.
    Matt
    Enjoying life in SW Florida
    Jan 2009
    NPR, FL
    Quote Originally Posted by arejayesss View Post
    It's an easy fix and a little more concrete cutting. I would not have the wm dumping past the shower and tub. Just to the north of you it would not pass.
    All they need to do is cut in a 3" wye before the 45 turn to the combo for the tub. Install a new 3" line towards the block exterior wall and run around the tub waste, cut the concrete towards the wm and install the new 3" line between the washer and dryer. Then remove the 3x2 combo to the shower and the 3" 90, bring the 3" line towards the wall, install 2 3"45's and a 3x2 combo center of wall(2" vent in the wall) with a 3x2 bushing in the head of the combo and a 2" 45 back towards the shower.
    Dunbar, here in Florida a bath group like that can be picked up on one wet vent.
    Default dwv
    The washer draining past the shower and tub drains can be a problem, but your salvation may be that since it is a 3" pipe the water velocity may not create problems. You either had a lenient inspector or a pemissive code.
    Aug 2009
    SW Florida
    Yes, the 3" does help, but still a no go. Unfortunately the inspector missed it, he didn't check for slope or anything. He just came and shook the stack with water in it and kinda glanced around. I just hope that they are willing to fix it.
    Florida Orange:
    I'm in Bonita, Work in Naples
    Jan 2009
    NPR, FL
    I have good friends down in Naples. Fish tournaments there every year in march. Hope they straighten it out.
    Feb 2005
    Talking it will work fine
    as HJ stated it will work fine, you are worrying about nothing,
    being a 3 inch drain it has to work,,
    if the inspector passed it, then the plumber isnt going to tear
    up that place to please you
    looks ok for indiana
    Aug 2009
    SW Florida
    I wish I could just let it go. My understanding is that when water from the washing machine drains past the other lines it will suck the p traps dry. This will in turn allow methane up through those drains, along with laundry suds. Am I completely wrong? I really just want it to work properly and not be a health and safety hazard to us when we move in.
    Dec 2005
    SW Florida
    It's doubtful that you would have the traps siphoned on a 3" line. If you really want to have the work redone by the plumber, technically his wetvent does not meet current code, the installation did meet code from a from about 8 years back.
    Matt
