Results 1 to 5 of 5
Thread: clawfoot tub question
    DIY Member K2's Avatar
    Jul 2008
    Delridge Valley
    Default clawfoot tub question
    please see the picture below, this is probably a stupid question but do I have to cut the pipes (A & B in the diagram) in order for it to line up with the drain and overflow holes? Or should it have been delivered with pipes that actually fit?
    I bought the whole 'clawfoot tub package' and this is the hardware it came with...
    Aug 2009
    South*East
    Yes it needs to be cut. This can be done with a tubing cutter or hack saw.
    John
    Jul 2008
    Delridge Valley
    thanks John, I was hoping I wasn't duped on my order
    Jan 2006
    Rosedale, Md
    Default Waste + Overflow
    Make sure that you have your measurments right before you cut it, you will be a mad ***x if you cut it too short!
    Default overflow
    That fitting is designed to fit "EVERY" tub, so you have to custom cut it to fit yours.
