Results 1 to 2 of 2
Thread: Pump will not turn off
    Default Pump will not turn off
    My well pump usually runs at 50psi pressure. It has been running at 30psi and will not turn off. When turn off the water to the house and out side the pump still doesn't turn off. The pressure went to 40psi.
    Well driller,pump repair. and septic installer Waterwelldude's Avatar
    Feb 2009
    Texas
    You have a hole in the drop pipe or the pump is bad, if it is a submersible.
    If you have a jet pump, there may be some trash in the jet orifice.
    Travis
    "I shall never surrender or retreat" -Col. William Travis
