Compression or Solder Fitting
GoldMaple
DIY Junior Member
Edmonton, Alberta
Does it matter if one uses a compression or a solder fitting for use as a bathroom shut off valve? Just two valves that shut off the shower, sink and toilet in the bathroom. Is there any reason not to use a compression fitting?
flamefix
Exeter, England
Only serviceability issues, which would be easier to replace..
