Results 1 to 3 of 3
Thread: Compression or Solder Fitting
    DIY Junior Member GoldMaple's Avatar
    Jul 2009
    Canada
    Default Compression or Solder Fitting
    Does it matter if one uses a compression or a solder fitting for use as a bathroom shut off valve? Just two valves that shut off the shower, sink and toilet in the bathroom. Is there any reason not to use a compression fitting?
    DIY Member flamefix's Avatar
    Sep 2009
    Exeter, England
    Quote Originally Posted by GoldMaple View Post
    Only serviceability issues, which would be easier to replace..
    Gas, Oil, solar and renewable service and installation in Devon UK- Please note my advice is not based on USA regulations as I am UK resident. Therefore I will try to avoid posting where confusion may be caused or make that clear.
    http://www.flamefix.co.uk
    Default valve
    Only servicability issues. Which will be most likely to leak and require replacement. Use the solder valve.
