Results 1 to 7 of 7
Thread: getting rid of hammer
    DIY Senior Member v1rtu0s1ty's Avatar
    Sep 2006
    Chicago IL
    Default getting rid of hammer
    I built a homebrew automated sprinkler system with the use orbit 3/4" sprinkler valves and garden hoses. It's just connected to the spigot outside. That means, it's temporary and I will have to remove it in winter. It's working pretty well.
    However, eventhough it's temporary, I would like to address an issue that I am experiencing. There are times when it turns off, I will hear a loud hammer on the pipes. About 85%, it happens. Are there any ways to prevent it without putting a hammer arrestor? I'm looking for a temporary solution if there are any.
    http://i303.photobucket.com/albums/n...es20090814.jpg
    Neil
    DIY Senior Member upper's Avatar
    May 2009
    Fresno, CA
    What type of valves.And how is it piped between the valve and the faucet? Upper
    Sep 2006
    Chicago IL
    Hi. This is what I have, 3/4 inch Orbit Sprinkler Valve 57100 model. Please see link below.
    http://www.orbitonline.com/products/.../02/16/04/643/
    The faucet is about 7-8" higher than the valve. I'm using a pvc pipe. Please see picture below.
    Thanks.
    The easiest fix would be to remove the brass hose bib with galvanized coupling,
    Replace the coupling with a threaded tee, and insert a threaded hammer arrestor in one side of the tee.
    what/how many heads are connected at the end of the hoses? how long are the hoses? what is the pressure?
    Sep 2006
    Chicago IL
    That's a very cool idea! I'm going to print out my picture and bring it to the store. Thank you so much!!!
    Sep 2006
    Chicago IL
    Quote Originally Posted by tomm View Post
    1st valve - one oscillating sprinkler
    2nd valve - one oscillating sprinkler
    3rd valve - 3 impact sprinklers
    The garden hoses pipe lengths are somewhere 60ft long per.
    I think the length of the garden hose doesn't matter. It's because, the hammer happens before the sprinkler valve.
