Results 1 to 5 of 5
Thread: standing water in clawfoot tub
Hybrid View
    Default standing water in clawfoot tub
    I just replaced the 80 year old drain and overflow assembly on my clawfoot tub. No leaks now but within 30 seconds I have standing water in the tub. Did the old ball joint on the drain create negative pressure that the new T doesn't?
    Any ideas or suggestions appreciated!!!
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    Quote Originally Posted by tsk0301 View Post
    within 30 seconds of what?
    within 30 seconds of turning on the showerhead
    Default drain
    Negative pressure would suck the water out of the tub. You have a plugged drain. Although you might have a poorly designed drain fitting.
    It drains eventually. Also, the sink and toilet are downstream on the same line and work fine. I also flushed out the p-trap on the tub before reattaching.
    The tub drained without any issues prior to the new hardware. I did not change anything below the floor, including alignment / slope of pipes.
