pump stops then starts
CaseyC
My well water pump runs for awhile and then the water suddenly stops for about a minute and then runs again. The water pressure never dies down or slowly rise back up. the pressure remains great. what could be the problem?
thanks
Gary Slusser
That's all folks!
What type pump do you have, jet or submersible? If submersible is it a constant pressure type?
If you know, what is the hp and gom?
If a submersible, is it 2 or 3 wire, 3 wire has a control box between the pressure switch and the pump.
What pressure range do you run the pump at? Normal is 30 on 50 off.
When the water stops, have you been using a lot of water for load after load of laundry or multiple showers etc.?
