Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Thread: DIY Sewer Mainline Replacement Plan
    Default DIY Sewer Mainline Replacement Plan
    I have tree roots growing into my clay pipe sewer line. I have had a camera sent down the line showing the root invasion in several of the joints. Since the first backup I have snaked the line yearly to prevent problems but this year the roots beat me to the punch and had a backup after 8 months. The wife says enough and wants the line replaced. The camera showed the roots invading the line underneath my property but not underneath the road before the sewer tap. My city will issue me a permit to work on the section before the right of way so I am going to try this myself rather than drop 8 grand. Here is my plan.
    I have gotten the plat for my house and know exactly where the sewer line is located. It is 6-7 feet deep at the house and 4-5 feet at the sidewalk. It is a 37 foot run from the house to the sidewalk. I plan to rent a mini-excavator to dig the trench and hydraulic shoring equipment to shore the sides. I am well aware of the safety issues here. Code requires 6 inches of pea gravel below the pipe and minimum 1/4 inch drop per 1ft run. I plan on using gasketed SDR-35, ASTM 3034 approved pipe which is accepted here by local code. Shielded Fernco couplings, guessing cast iron to plastic at the house and then plastic to clay at the sidewalk. Plan on installing cleanouts at the house and sidewalk.
    Questions:
    1. What do you recommend using to make a clean straight cut on the clay pipe to accept the Fernco?
    2. Any issues to think about when backfilling to avoid affecting the line?
    3. Anything else?
    ABSOLUTELY a MUST to have a "dig alert" service survey the area. The dangers and liabilities from digging up possible water, gas, phone, electrical...are large. And in most places, the LAW requires the use of dig alert.
    Are you aware of how much hand digging will also be involved? How long are you prepared to be without sewer while you work on this?
    Plumber Cass's Avatar
    Nov 2005
    You will need a full size back hoe for this a, mini will take 3-4 times longer and may not even work...I think they do 6-7' deep but that is it's max depth not the working depth...do you also have a drag box so if the trench colapses they won't be just backfilling and placing a marker on the spot you died....what size bucket are you using...
    scratch-pad engineer and mechanical fabricator leejosepho's Avatar
    Nov 2006
    Even as an avid DIYer who will tackle just about anything, I suggest leaving this one for the pros. And if I could not afford that, I would install a pump with a shallow line going out to the street.
    Default sewer
    A mini hoe will not have a bucket wide enought to dig the ditch you need for a 6' to 8' deep sewer. Between that, and the shoring, I assume you will be spending most of that $8,000.00 anyway, assuming that is really what it would cost. I would NEVER use SCR pipe at that depth. It crushes at 4' and has to be replaced.
    Thanks for the repsonses. I already called and had the ultilies marked, nothingwithin 12 feet of the trench.
    I can get a mini-excavator with an 18 inch bucket that digs to 11 feet or a backhoe with I think a 24 inch bucket that digs to 14 feet, that big enough?. Both are around $250 a day.
    The SDR-35 is OK with the city. My neighbor just had his line done, same depth as mine and that's what they used but I could go with the SDR-26 if that is better. Don't know if sch. 40 PVC is approved or not but could check if that is recommended.
    Nov 2008
    Chicago, IL
    I would spend the few extra bucks and use SDR-26 pipe with the SDR-35 fittings. SDR-35 pipe is junk. If you are in the Chicago area, and you are only replacing 40 foot of pipe, I can do the whole job for around 4k.
    Default pipe
    Sch. 40 pipe is ALWAYS permitted and is the only thing I would use.
    Nov 2008
    Chicago, IL
    I have inspectors here that will only allow Sch 40 underground outside is when the water and the sewer are in the same trench or less than 10 feet apart from each other.. Thats when the code states that if the water line and building sewer line are in the same trench the material must be of building drain pipe.
    Now if there is a 10 feet separation of the water and sewer, then the sewer pipe must conform to the standards of approved materials for building sewer.
    The building sewer standards are ASTM F 1866-1998, ASTM D 2665-1998, ASTM D 2949-1998, ASTM D 3034-1998, CSA B137.2-1999 in B137, CSA B181.2-1999 in B137
    The building drain standards are ASTM D 2665-1996, ASTM D 2949-1987, CSA B182.1-1999 in B1800, CSA B182.2-1999 in B1800, CSA B182.4-1999 in B1800, CSA B181.2-1999 in B1800
    Of course this is Illinois plumbing code which is the states care minimum. Cities, and counties can make it stricter. I had a county inspector had me use ductile iron in the park way for a building sewer.
    DIY Member JAR8832's Avatar
    Feb 2008
    Wisconsin
    What is the reason they don't like SCH 40 for a sewer line?
    I will use whatever is the best pipe as long as it is approved by code. So is the consensus sch. 40 over sdr-26?
    Back to my first question. What's the best tool to use to make a clean straight cut on the clay pipe? Grinder with a diamond wheel?
    Dec 2007
    Quote Originally Posted by sctclimbs View Post
    Chain Snapper!
    Soil Pipe Cutter
    Nov 2008
    Chicago, IL
    I basically said SDR-26 if there is a 10 foot separation of the water supply and the building sewer. If the water and the sewer are closer than 10 feet then it has to be SCH 40. Check with your local codes first. There are a few towns around here that want cast iron instead of SCH 40.due to their codes stating that they do not allow SCH 40 to be used underground as a building drain.
    As to cutting clay pipe the chain snap cutters is the best way to cut clay pipe, as Redwood pointed out. Also the couplings to make the connection from the clay pipe to the plastic pipe should be no-shear couplings.
    Default sch 40
    If SCR is acceptable, then sch. 40 would be a major upgrade and NO inspector should reject it. I have never used SCR, and ALWAYS use sch. 40. But I have replaced flattened SCR sewer lines. Remember, Orangeburg was also an approved material at one time, so just being permitted by the code does not mean it is a "good" material.
    Called my water/sewer district today and they will not approve sch. 40 saying that ground movement can fracture the glued joints. I live on the side of a big hill with type B soil. He recommended the sdr-35 but when I asked about sdr-26 he said that would be fine, so I guess I'm stuck with that.
