Results 1 to 7 of 7
Thread: Brass Unions
    DIY Senior Member BimmerRacer's Avatar
    Jan 2009
    Washington, DC
    Default Brass Unions
    Do I need to put anything between two halves or do I just crank it down to seal it?
    Nov 2008
    Chicago, IL
    Just tighten them down the ground face of the union will make the seal.
    Jan 2009
    Washington, DC
    Thanks Ron!
    A couple of things...make sure the pipes are aligned when you tighten things up. And, especially if you overtighten, you may find you create a ridge on the sealing surfaces, so if you need to tak it apart, it becomes more difficult to seal unless you get it aligned perfectly.
    Default unions
    I usually use pipe joint compound on the faces and the threads of the union nut to give some lubrication to the process.
    Jan 2006
    Rosedale, Md
    Default Unions
    Do to the fact that most fittings are made off planet, I also use a little pipe compound on the face, your choice.
    Jan 2009
    Washington, DC
    Thanks for the tips gents
