Results 1 to 7 of 7
Thread: Washer stuck to copper pipe
    Unhappy Washer stuck to copper pipe
    Hi
    We are trying to fit a plastic speed fit elbow 15mm onto our water pipe in our bathroom in order to connect a new shower unit to it. However we cannot remove the old copper washer used with the existing fitting :? - (I think it's called an adaptor?)
    We cannot use the existing fitting as we have had the walls plastered & re-iled (they needed it!) & this has resulted in less space between the shower unit & wall. The speed fit connector gives us the extra centimeter we need to get the shower back on for a perfect fit!
    We have tried everything to get the washer off but to no avail, any advice offered would be greatly appreciated.
    Default washer
    Depending on what you call a "washer", it could be a ferrule in which case you need a "ferrule puller" to extract it.
    A picture would help. Your use of the term "washer" may be inaccurate.
    Assuming you are talking about a ferrule used in a compression fitting, the ferrule puller should work. It's sort of like a gear puller, they come in various sizes.
    Smile Further info
    Hi
    After some more internet research I've found out that it's a compression ring & nut, & the nut is stuck, it seems like a common problem, but I couldn't find any info before as I didn't know the correct terms!!
    So I think a puller would be the answer, hopefully, thanks for posting back
    Tools like this puller are fairly easy to find in rental stores in the US. I infer that you are not in the US since you are using metric sizing. You might shop a bit more and see if you can find a brass fitting instead of the plastic.
    Default ferrule
    Another problem might be that ferrule pullers usually only come in the size to remove 1/2"-5/8"" ferrules and you may have a different sized copper tube.
