I have a deep well submersible pump with Well-X-Trol Model WX-202 pressure tank, Square D FSG2 Class 9013 Series B pressure switch, Franklin Electric #280-1070-101 3/4 hp 60hz 1-phase 3450rpm Control Box. Believe the well/pump is about 300 feet deep. House and well build in 1977. Noticed a week ago that pump kicked on/off a few times when no water was being used. A few days ago, started having low pressure all over the house (it's happened b4 and so I didn't think to check the psi gauge). Then it went to pencil-size trickles and I noticed pump was not coming on and the gauge shows 0 psi. Turned off circuit breaker and heard all water in pipes and water heater draining back into the pressure tank. When turned CB back on, got a small trickle at all faucets/baths. Today it went to NO water. Power is back on, still have 0 psi and pump is not kicking on. There is no visible shut-off valve outside or inside between water entry into basement and the tank. Does this sound like a simple fix (like power off and clean nipple/change pressure switch and/or control box)? Even if not a simple fix, I would like to be pointed in a direction where I won't be ripped off by outside service. I have a good Fluke multi-meter and generally good at fixing things. Thanks very much for any help or reply. PS This site is great!
