3 wire pump
buckeye
replacing a 3 wire water well pump, old wire is only 3 wire. a 3 wire pump has 4 wires how did they do this?
Waterwelldude
Well driller,pump repair. and septic installer
Texas
The red, black, and yellow, go in the same place as the old pump. The green wire is a ground
Travis
buckeye
they only had a 3 wire going down hole to the pump, a pump with 4 wires
Waterwelldude
Texas
Unless you want to buy 4 conductor submersable pump wire, cut the green one off the pump, or strip about 3", and rap it around the end of the pump.
That green ground wire is supposed to go all the way to the control box ground screw.
Travis
buckeye
my pump has the yellow wire connected to the blue, does the blue go to yellow spot in box or to ground as on switch
Waterwelldude
Texas
the red wire goes to the red in the box
the yellow goes to the yellow in the box
the black goes to the black in the box
the green goes to the ground in the box
They can not be changed in any way.
buckeye
my pump has 4 wire red, yellow, green and black, we stripped the green and wrapped around the pump, the wire going down hole is 3 wire black,red and blue, the blue hooked to yellow, in the box should i have 2 wires and blue to ground, as in the switch red and black with blue to ground, or should it 3 wires to strip
Waterwelldude
Texas
The wires can not be changed in any way.
If the yellow wire is spliced to whatever color it has to go to the yellow in the box.
The green is the only ground. If the wires or not put in the box in there slot it will not work.
