murrayd
- Messages
- 11
- Reaction score
- 0
- Points
- 0
I have a submersible with 1 1/4" poly pipe coming from it to the pressure tank in the basement. I'm planning to put an underground sprinkler system in. Today I teed into the 1 1/4" line, just before the pressure tank and ran the line outside with a valve and a proper backflow valve. I wanted to fill a 50 gallon drum and time it so I can figure what I have for GPM for the system. (I need this number to plan properly). Anyway, I tried to run the line into the barrel but my pressure switch keeps shutting off. It's one of those safety pressure switches that will cut off if the pressure drops too low. I'm wondering two things. First is it okay to tee in where I am, before the pressure tank? Second will a standard pressure switch fix my problem with the safety one shutting off?
