If it is a drop-in tub setting on a platform, unless you do with something like a circular or oval shower curtainrod, there'd be no way to contain the spray. Then, you'd need some way to plumb water to the showerhead. Depending on the valve, you may be able to replace the tub spout with a divertor type to activate a showerhead, but need more info to tell. It probably won't be easy, but you might get lucky; just can't tell from here.
