Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Pedestal sink in new home- supply lines through floor?
    DIY Junior Member HC's Avatar
    Aug 2009
    Default Pedestal sink in new home- supply lines through floor?
    Please help! I am building a new home and the plumber has the hot and cold supply lines coming up through the floor. My builder states that this is the "easiest" way to do the plumbing and that the pedestal will hide the lines. The lines are about 3" off the wall and about 8" apart. Is this standard? Should I have the plumber move the supply lines to come out of the wall?
    Thanks for any help!!!!!!!!!!!!!!
    DIY Senior Member TedL's Avatar
    Sep 2006
    NY Capital District
    First, let me ask you, how much are you willing to pay for this "upgrade"?
    DIY Junior Member inertiacoupling's Avatar
    Oct 2007
    Fishers, IN
    I'm not a plumber, so I can't answer whether this is "standard".
    My house I grew up in, built in 1959, has a wall mounted sink in one of the bathrooms.
    It has two straight chrome water lines coming straight up from the basement in a similar fashion to how you describe.
    The install is nice looking and clean.
    I'm replacing the sink, and considering using a pedestal sink.
    i will continue without hesitation to use these type of water lines to the sink, because they look good in this installation.
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    the pedestal won't hide the water lines if they are 8 inches apart. they shold be coming out of the wall. I put mine 4 inches apart at about 24 off finished floor, centered on the drain (the drain is centered on the sink)
    Jul 2008
    S. Maine
    Not only won't the pedestal hide the lines, the lines and the valve and the escutcheons will all have to be chrome with rigid supply lines if you want it to look good.
    Aug 2009
    Default Cost for upgrade
    TedL,
    What do you think is a fair charge for this upgrade?
    Aug 2009
    TedL,
    Thanks for the info!
    Default upgrade
    Absolutely no way for us to say, since we have no idea what is involved for your house.
    Aug 2009
    Any ballpark number. It is new construction, 5' x 6' 1/2 bath, on an inside wall. No obstructions in the way of heating/cooling and electric.
    Aug 2009
    Also, on 1st floor of home over unfinished portion of the basement.
    DIY Senior Member jastori's Avatar
    May 2008
    Illinois
    Is the sink on an exterior wall in a cold climate? That could be one reason for not running the supply in the wall.
    Otherwise, I would say "standard" is to have the supplies in the wall. I would push for him to do it the "standard" way at no extra cost to you. Is the drywall up yet? If not, it is not a big deal to change it now (maybe an hour for the plumber). I doubt that the supplies will be hidden by the pedestal base (depends on the pedestal itself).
    I would want the plumbing done in a way that is the most flexible for the long term. If you switch to a different sink (with a base cabinet) sometime down the line, you may not be happy with the supply in the floor. Plus, having the supplies in the floor is not convenient for cleaning (mopping around the pedestal base).
    Aug 2009
    Jastori,
    Thank you for your advice! The sink is not on an exterior wall and the drywall is not up yet.
    Sep 2006
    NY Capital District
    "Fair price" and "cost to builder" are often irrelevant in situations like this. You may want to see if he'll let you have your own plumber change it. Of course, they could still want to ding you for making the fixture setting "more difficult". If the first plumber's done with the rough in work, it's no cheaper for him to come back than any other plumber. And you're more likely to get a real, competent plumber hiring your own.
    You have a contract you're trying to change. They have you by the....uh, where they want you.
    Most pedestal sinks have VERY specific locations of both the drain and the water supplies, or the pedestal won't fit right. Before you move anything, make sure you have the pedestal and sink's installation instructions. Any decent one will have a diagram showing exactly where the valves and drain are supposed to be. Any other way is a guess, and not likely to come out well. The only standards are hot on the left and cold on the right.
    Aug 2009
    Actually, no where in the contract does it specify that the lines will come out of the floor.
    This is a custom home and there are no "change orders". We can have anything done that we like- at the right price. So, what would someone charge to hook up a pedestal with supply lines off the wall instead of through the floor? If I have to, I will put in a furniture vanity.
