Results 1 to 5 of 5
Thread: Sill plate location ... in or out?
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Default Sill plate location ... in or out?
    Do I set my sill plate on my foundation out the thickness of the sheathing so that it's flush with the outside of the sheathing or do I set it back so that it's flush with the framing?
    Any advantage in putting down a sill sealer if I'm not insulating or heating the building?
    Jason
    Default sill plate
    Usually you put it even with the framing and then use a "J" metal or similar to set the siding onto.
    Aug 2005
    Columbus, OH
    Flush with the framing it is. Thx
    DIY Senior Member jch's Avatar
    Jan 2006
    Victoria, British Columbia, Canada
    Quote Originally Posted by Lakee911 View Post
    Yes, it will act as a moisture barrier between the porous concrete foundation and your wooden sill plate. Building code (here, at least) specifies that untreated wood can never be in direct contact with masonry.
    ../j
    - John
    Aug 2005
    Columbus, OH
    Thanks for info. My sill plate will be a pressure treated 2x6. Upon that I'll build a 2x4 wall. I think that I'll put down anyhow.
    This is in regard to the garage that I'm building. Check out progress here.
