loudhornsrule
My well will produce about 7 gpm . Anything more than that is asking for trouble. 18' to static water 22' more feet to bottom of well and pump. 40' total length of casing( 6'' casing w 12'' borehole)Also 20 gallon pressure tank. Im scared I am going to run my well dry and burn my pump up.(sometimes we water 12-24 hours!) I am going to replace my pressure switch w/ one that has pump protection. I value all you guys input, so what pressure switch would you go with? I only water the yard with this well(alot). thanks
