"Singing/Whiring" Water Pipes
ironwmnmk
My home is 55yrs old, on slab foundation, with copper pipes that I believe run through attic, and gas water heater. Have lived here 16yrs. and just now when using shower (with single handle Moen regulator installed by plumber 5 yrs ago) there is a loud "singing/whiring" noise that can be heard through wall. The sound begins after the water has been flowing through tub spout for a minute or so, changes pitch when tub diverter is flipped to showerhead, and also seems to change pitch depending on temperature position of valve. There is no banging as with hammer noises. Seems to be only the shower/tub lines that produce this noise. House is only 1000 sqft, so all plumbing (kitchen sink, washer, toilet, bathroom sink and shower) run through the same 10 ft. length of wall. Any ideas as to what causes this noise, is it an EMERGENCY that requires immediate (Saturday) attention, and is there anything else I should be concerned about? Thank You - I'll check back throughout the day - Michelle
Master Plumber Mark
www.weilhammerplumbing.com
no emergency
If it only does it when the tub-shower is turned on
and you dont hear it any other time....
its most likely something simple to dowith the
MOEN tub + shower faucet.... first thing I would do
is change the tub diverter spout and see what happens...
if that does not fix it, then you need to get a new cartridge in
the faucet...
its probably something simple like that...
go ahead and make your plumber happy and
wait till monday. Let him have a day off.
