From my research online I think that I may have a ruptured well tank bladder, but I wanted your guys opinions.
I have a well-x-trol wx 202. Whenever I run water, flush the toilet, etc., my well pump kicks on and off at an interval of about every 5 seconds when water is running. When it stops I here a trickling of water inside the tank.
I'm thinking my pressure switch is a 40/60. It sits at 40 constantly. I let the water run an watched it as the pump kicks on and off and it sits at 40.
I pushed the valve to see if water comes out, and I got a bit of moisture out. I thought if the bladder was broke I'd get more of a spray?
I also tried rocking it a bit. I didn't want to push too hard with all the piping, but I did hear splashing near the top. I'm am not sure how much if any water I should hear splashing.
I thought it might be a pressure switch problem at first, but I think it might be a tank issue.
I'd like to handle this issue myself without calling someone in.
Thoughts?
-Tom
Thoughts?
-Tom
