Results 1 to 6 of 6
Thread: Siding/sheathing - ran into a doozie
    Default Siding/sheathing - ran into a doozie
    Hi everyone - first time poster!
    Today I started demo on the back side of our house to re-side with hardiplank siding. All went well until the very last piece...
    Under the sliding glass door, it appears that the siding was finished down to the sill plate like the rest of the house and the concrete step (2-steps) was added later - flush against the siding. There is the top of the bottom course of siding even with the top of the stairs. The sheathing appears to be infested with ants and also possibly water damaged. I checked the back side from the crawl space and there is thankfully no damage visible to the framing (the OSB sheathing is two sheets thick).
    There is no reasonable way I can think of to get the siding off and replace the bad section of sheathing due to only having about 1/8" gap between the back of the stairway and the siding board.
    Any ideas that don't involve jackhammering out the stairs?
    Yakima WA
    Not if you want to do it right. There may be several hack ways of doing it, but probably none of them would be any easier, cheaper, or much less better than getting a fresh start.
    Ouch,
    That might be tough.
    I've seen steps poured against the siding before.
    Now we know what happens.
    Yeah it's pretty lame... I'm going to try to slide a hacksaw blade behind the siding to get it off and see if that gives me enough room to work on the OSB. Even if it works, I don't know if I will be able to get it back together the 'right way' so there I don't have any future problems!
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    I wouldn't want to take those steps out... I would try to treat the pest problem, dry it out and clean it out as well as possible and then provide some flashing around the steps. It wouldn't be right, but it might be better.
    Have you considered accessing the area from the back side of the steps? Removing the sill plate, joist, etc might be tough but it would give you some more space to work perhaps.
    Jason
    Extreme DIY Homeowner Scuba_Dave's Avatar
    Jan 2009
    South of Boston, MA
    My front patio and my back patio were both poured after the house was shingled
    I enclosed the front with a small 3 season porch - 6x10"
    I used a chisel, sawzall & other assorted tools of destructionto get the shingles out
    The back patio actually sloped towards the house about 2" over 16'
    I built a sunroom on top of the patio
    Went thru the same trouble getting the old shingles out
    My main concern was damage to the rim joists - this was minimal
    There was a 3 season sunroom on the back patio at some pointin the past
    So that prevented a lot of rot
    DIY Handyman (not 4 hire)
    I have enough to do to my own house
