Thread: No Room For P-Trap on Washer Standpipe
    DIY Junior Member DigitalJim's Avatar
    Aug 2009
    Rochester, NY
    Default No Room For P-Trap on Washer Standpipe
    I am moving my washer 12' and installing a new 2" drain. Due to the placement of the washer box, a standard off-the-shelf p-trap won't fit without cutting out a large portion of the stud (vertical of p-trap falls in line with stud).
    Is there any reason why a built up p-trap using 90 deg elbows would not be allowed and/or recommended? Also, is there a width limitation on a trap? I would have to extend the width on the bottom of the trap about 3" to pass through the stud.
    Thanks in advance for any comments.
    Dec 2005
    SW Florida
    Why not pass through the stud with the vertical waste and then install the trap?
    Matt
    Enjoying life in SW Florida
    Exactly.
    Just place the p-trap within the stud space, and use two 45 els up to the box.
    Aug 2009
    Rochester, NY
    I'll have to check the clearance, but I believe I can do that.
