Results 1 to 6 of 6
Thread: unscrewing pipes: counter or clockwise?
    Default unscrewing pipes: counter or clockwise?
    Ours are so tightly screwed that I can't get then to budge, and now can't remember the rules for counter or clockwise.
    DIY Senior Member Rich B's Avatar
    Sep 2008
    New Jersey
    Lefty-Loosey Righty-Tighty
    DIY Senior Member TedL's Avatar
    Sep 2006
    NY Capital District
    Depends on which way you're looking, and which part you're talking about.
    For standard, right hand threaded fittings:
    Pipe, one end close to you, fitting at far end of pipe. Turn pipe clockwise into fitting; CCW to remove from fitting.
    DIY Senior Member seaofnames's Avatar
    Jan 2009
    Mission, BC
    My brother just picked up the 15 amp version of the sawzall...you NEED 15 amps!!
    Yakima WA
    My Porter-Cable Tiger Saw will also do the job. About connecting and disconnecting pipe. It works exactly the same as a hose connecting to a faucet or another hose. Also, nut and bolts turn the same direction (although there are special applications that use left-hand threads)
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    I always remember it like I'm taking off a pop bottle lid ...
