Hi -
I have a 1 year old well that I'm having issues with. The well is 420 ft deep with a static water level of 100'. I have a Grundfos 10SQ15-330 pump that pumps water into a cistern, from where it's pressurized for the house by a Grundfos MQ. I have 2 issues:
First, the water has never cleared up since the well was drilled, having very fine grey silt (turbidity?) that will not settle out. I've had the water tested by a lab, and there's nothing outside 'normal' limits except the turbidity. I was able to clear the water by putting in a big-blue filter with a 0.35 micron element, but the element clogged up after about 1000 gallons. A 5 micron filter does not clear the water.
Second, the Grundfos SQ is supposed to have a built-in check valve, but it doesn't seem to work. When I turn the pump on it takes upwards of 20 seconds for the water to reach the cistern, and once it arrives is spit's and spurts for another 5 seconds or so. I assume this is due to air in the water line, which I assume the check valve should prevent.
My suspicion on the silt issue is that I may have set the pump too deep. I have 400 ft. of 1" PVC in the well, and the Pitless adapter is approx. 10' below the well cap. I'm not sure how much PVC stretches, but could it be possible the pump is too close to bottom?
I have no suspicions on the air in the waterline, or if the two issues are related.
I'd welcome any input or suggestions. Right now I think my options are to pull the pump, remove a section or two of pipe, and add a check valve.
Thanks.
Thanks.
