Thread: Need Help
    DIY Junior Member wmills's Avatar
    Jul 2009
    NC
    Default Need Help
    We just closed on a house that our family loves. Just one problem, no hot water. I checked to make sure the power is run correctley. Checked the elements They were both good, replaced them with new ones anyway, worth the cost for the future. Still no hot water. I am now thinking in the way of replacing the thermostats. Cant be much else that I can think of. The tank is about five years and I think it is worth fixing instead of replacing. It is about thirty gallons underneath the house. I always hated water heaters under the house.
    Any ideas will be appreciated.
    If there's power to the WH, then it's either the elements, or the thermostat, or, the water is turned off, or clogged up and can't flow. Do you get flow but it's cold?
    You need a meter.
    Default heater
    I am not a big fan of guessing why things do not work and just start replacing things until they do work. You would not let your car mechanic do that would you, (although a friend of mine did have something like that happen to her a few weeks ago, until I told her what the problem was and the mechanic fixed it). Test the elements, and thermostats, AND power to the heater before doing anything. Find out where the problem is and then fix THAT and nothing else. For example, you could have a burned out wire in the heater's junction box, if the heater has aluminum wire to it.
    Jul 2009
    NC
    I am not a fan of just jumping into the change parts attitude. Turns out I had a circut breaker with one leg that was frying causing intermittent power. I replaced it and now it works great. I had changed all the parts Knowing that the parts are not that expensive and after draining the tank I wanted a fairly fresh start. Thanks for the help and sorry for not replying sooner but have been offline for a couple of weeks due to the move.
