Results 1 to 9 of 9
Thread: Help needed!PLEASE!
    DIY Junior Member destiny01's Avatar
    Aug 2005
    Canada
    Default Help needed!PLEASE!
    We are in the middle of remodeling our bathroom,tearing all the walls out but my question is after we are finished all of that and removed toilet,tub,etc.what is next? Do we insall new tub,toilet then put up walls and electrical stuff or walls before tub and toilet installation?My husband really doesn't know and he will have help but I want to make sure he does it all right so we have fewer opps! I wish I could find a step by step on what to do in what order.I get headaches just thinking about everything.If anyone can help me out,Thanks!
    Default remodel
    The headaches, and scheduling problems are why homeowners use general contractors or specialty contractors to do it. Without them, many marriages do not survive a major remodel.
    Plumber RioHyde's Avatar
    Cincinnati, Ohio
    Once you're down to the stud walls, remove the old tub and replace it with the new hooking up the waste, overflow and trap as well as the new tub/shower faucet. In addition, any other plumbing work within the walls as well as any other type of item (electric) also in the walls can be done at this time. Install the drywall, cement board, wall tile, etc. then the flooring then paint. After that install the vanity and the toilet.
    I'm sure there are other ways of doing things, but this process works for me.
    Good luck
    Aug 2005
    Canada
    Thanks guys! hj-unfortunately we don't have the option to hire anyone and i've heard that even that way can be just as much of a headache!LOL!Hopefully we will make it through,we've definately made it through harder things.
    RioHyde-Thanks again for the help,I had my husband look at this and hopefully this weekend he can get started,who knows just how much will be accomplished but at least a start.
    DIY Senior Member thezster's Avatar
    Jul 2005
    Fort Collins, Colorado
    He's right... though from the sounds of it, you're possibly not sure what he said.....
    Go to Home Depot... buy a 14 dollar book on remodeling bathrooms.... they're very simple, very thorough, and easy to follow..... You're tackling a big project ... but it's not as hard as it initially sounds... Good Luck
    Oh yeah..... tear everything out.... replace the tub.... then the walls, floors, then cabinets, sinks, and toilet last of all.....
    Aug 2005
    Canada
    Thanks thezster!Sorry,I must have misunderstood,I thought a general contracter was someone you had to hire to do the work for you .I'm not very good with all this stuff. That is why I am only helping to tear down everything,that I can do! My husband is going to have someone with more experience ,has done a bathroom before help but like my husband always tells me I like to second guess everything and make sure it is going to be getting done the right way.He does also like getting other peoples opinions too.
    I second the suggestion that you get a good book, but you must also realize that these how-to books can't cover everything and you sometimes have to be creative and still stay within codes. I have found that the "Box Stores" often have a few very knowledgable and helpful people in their plumbing and electrical departments. The trick is to separate them from the rest of the salesmen. I think a fairly good rule of thumb on remodeling is to keep in mind you are building from inside the walls, floor, and ceiling to the outside.
    DIY Senior Member sulconst2's Avatar
    Jul 2005
    old bridge nj
    i think it takes more than a "book" to remodel a bathroom from start to finish. you have to be skilled in plumbing, electric, framing, spackling, tile and finish work. without hiring pro's in each area you need to be a skilled craftsman or it will show in the finished product.
    from a remodelers standpoint, kitchens and baths require the most skill by far than other remodeling projects.
    Jul 2005
    Quote Originally Posted by sulconst2
    Can't agree more... I guess I take it for granted that everyone has these basic skills.......... and after thinking about it... should know better! The "book" is a great resource.... on top of experience...
