Results 1 to 11 of 11
Thread: pump motor overheating fast
    DIY Junior Member Randall59's Avatar
    Jul 2009
    Canada
    Default pump motor overheating fast
    I just installed an older Myers 'Ejecto' pump driven by a 1/2hp GE motor. When turned on while still cool it only runs for about 2 to 3 minutes before it gets very hot and the 'thermally protected' motor shuts off ( the pump pressure switch is still in the on position ). It stays off for about 5 minutes and then it automatically comes back on but as it is still quite warm, it only runs for 30 seconds or so before turning off again. I'm guessing that it has something to do with worn brushes in the motor or something similar. Can I fix this ?
    Thanks.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by Randall59 View Post
    Thanks.
    Motor needs to be water cooled[submersible]?
    Shorted winding causing overheating?
    Pump bearing worn and causing too much friction?
    Check your voltage across and current through the motor. I don't see how motor brushes could cause this.
    This link courtesy of another member
    http://www.franklin-electric.com/bus...M/page-46.aspx
    Moderator valveman's Avatar
    Mar 2006
    1/2 HP GE motor? I am guessing it is air cooled. Do you have it wired 115 volt and it is set up for 240V?
    Jul 2009
    Canada
    Here is the pump and motor
    Jul 2009
    Canada
    It came wired for regular electric plug-in, and is the same set-up as my last pump.
    Also, are the motors interchangeable ? I have the old pump which is a Jaccuzzi with a 1/2hp Franklin Electric motor.
    Mar 2006
    Pull the end cap off the motor and check voltage setting. I still bet it is wired for 230 volt and you are plugging into 115 volt.
    Default wiring
    If it were a factory wired cord, then there would be little doubt that the motor was wired for 120 v. But that is a field cord installation so the actual wired should be verified. Bad bearings, rusted volute dragging on the impeller, or wrong voltage will all cause the problem.
    Jul 2009
    Canada
    Pull the end cap off the motor and check votalge setting. I still bet it is wired for 230 volt and you are plugging into 115 volt.
    BINGO!!!
    There was a small 'pull out, turn, push in' hi and low power setting button. I set it to low power and it works perfect.
    You guys are AWESOME!
    Thanks much.
    Mar 2006
    I brought this thread back up because some people may not know that pumps can run on half voltage. I have had 240V well pumps that electricians wired up to 115V after I was gone, that ran for a year that way before I happened to find it on a service call. Some will actully pump pretty good pressure, and not trip the overload.
    Aug 2008
    MD
    115v should give a little more than 1/4th the power and 1/2 the current of 240v because the motor will try to draw more current to meet the demand. They should give about 1/4th the GPM or the pressure, assuming the efficiency is the same, which it almost certainly is not.
    Do you think this low voltage shortened the life of the motor?
    Mar 2006
    Quote Originally Posted by Thatguy View Post
    Probably but it ran for many more years after switching it back to 240V. It seemed like it was doing about 1/2 what it should on the 115V.
