Results 1 to 8 of 8
Thread: How can I tell if my wires are live?
    DIY Member coopns's Avatar
    Sep 2006
    Massachusetts
    Default How can I tell if my wires are live?
    I took down a fixture to replace with a ceiling can light. My box is labled very well so I am not sure what circuit it is. I don't want to buy a "not sure what they are called...tester", is there some other way to test those two wires without getting zapped?
    Turn off ALL the power Einstein.
    Maybe it would have neem a good idea to find the circuit when the fixture was still installed??
    If there are only two wires in the light j box (one black, one white) turning off the switch will turn off the power.
    If there are more than two wires up there, turn off the circuit somehow.
    A simple tester is dirty cheap. All they are is a glow light with 2 leads that you touch to the wires or push into a socket. If the light glows, the wires are hot. These are not high class meters or voltage readers, just is there power or not.
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    Quote Originally Posted by coopns View Post
    Heavy gloves and the neighbors cat.
    Plumber Cass's Avatar
    Quote Originally Posted by 220/221 View Post
    Maybe and maybe not...if the neutral was switched by a DIYr instead of the hot it will still be live...always use a meter / tester to test a curcuit, test it on a known live circuit first...ask me how I know...
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Testers/voltmeters (except Wiggys) indicate phantom voltages so instead use an incand. lamp in a socket with pigtail leads.
    My dad and I used to take our fingers wet them, and briefly touch a hot wire. I wouldn't recommend this.
    Quote Originally Posted by Thatguy View Post
    Not better multimeters. But still a simple tester here will do the job.
    I consider myself an accomplished DIY'er. I don't know everything but help where I can. I'm not a pro, but like to think I'm professional.
