expert87
Hi;
I need help choosing the correct AC size for my room
the room is about 320 squared feet "32 meter squared"....It is connected directly to my kitchen "small one...about 190squared feet"...the kitchen has no cooling unit, ventilation fan is on when cooking only and air flow is at minimum so pretty much the hot air sometimes is trapped inside..
The room I want to cool is also connected to a hallway "very small" that leads to the bathroom and the other room"bathroom no ventillation fan due to insects attacks!...just using the windows as a ventilator...so it is very humid around there.
I have bought 2 windowed ACs for the 320 feet squared room in less than 6 years.
at first the AC works great...after sometime freon runs out....refill....then after sometime just a sudden compressor failure....the ACs I used where 2.5tons "we use metric systems here"and they all failed to cool the room perfectly....just at night when everyone is asleep I get up and increase the temperature.
so what kind of AC and what power is porper for this room??....the room is not insulated "I mean heat insulation"...and I don't plan to change the status of the other rooms connected to it cause no space for cooling utilities.
One extra thing....the climate where I live is very humid usually....temp at these days goes up to 122F-130F
Sorry for the lengthy question....had to make every thing clear.
