Results 1 to 7 of 7
Thread: circut breaker tripping need help!!
    Unhappy circut breaker tripping need help!!
    Was having trouble with water pressure at faucets so I checked the tank pressure and it seemed low. Determined it was a bladderless tank and added pressure. This problem occurred more than once. Woke to no pressure and tried to determine the cause. Then the breaker began tripping as soon as I turn on the pump switch. I replace the control box after reading about it being the likely cause. After installing the new box I turned reset the breaker and again the circut tripped. What should I do next or what are possible senarios
    Plumber Cass's Avatar
    Assuming all you did is correct...it could be a short or a bad pump...
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Or a bad breaker or a bad connection to the breaker.
    I'd invest in a clamp-on ammeter so you can measure the current going through the breaker. It'll pay for itself quickly.
    DIY Senior Member upper's Avatar
    May 2009
    Fresno, CA
    If you can not pull your own pump,now is the time to call a pump guy....Upper
    Default thanks for the advice
    When I was connecting the new control box, I noticed the red wire had some spots where the wire was visible. Could that be the source of the short!?! I will consider getting the meter to see what is flowing through the wires. Could a defective pressure switch cause the fuse to blow? Again, thanks for the help.
    Jul 2009
    North Vancouver, BC
    Default Circuit breaker tripping
    One quick check would be your connections in the wiring. Sometimes in a repair you may have loosened a connection and vibration is causing the loos connection to spark and those trip the breaker.
    Check that all your connections are tight and the copper is in good condition.
    Sometimes it's just that.
    We had a floor heat thermostat that was tripping all the time and it turn out to be one loose wire that vibrated when the kids ran down the stairs.
    Default Many thanks
    Will check connections for loose wires and the bare copper wire I mentioned in the last post. Thank you for you imput and Love for this wonderful forum...I have learned sooo much!!
