plumbbob
- Messages
- 27
- Reaction score
- 0
- Points
- 0
Hi - jut about to order a new toilet to replace the original 1920's two piece unit which is now failing. The existing rough in has the bolts at 13.5 inches from the wall. Obviously i can just put the new unit on the existing bolt placement, but it will 'push' the toilet more into the room than necessary. And I'll have a reasonable amount of space behind the tank (about 2.5 inches buy my count).
Is there an easy way to avoid this and 'move' the bolts back? I'm going to assume it's the same 3 inch cast iron flange i've found in the other baths around the house.
Maybe the answer is not in moving the bolts but in an installation kit? I know Toto makes some units (like the Lloyd) to accodomate odd rough ins...
Thanks, Matt
TOTO Lloyd with the softclose Maple seat.
Thanks, Matt
