Results 1 to 6 of 6
Thread: Gas line within NYC code?
    DIY Senior Member Andrew21's Avatar
    Jun 2006
    New York
    Default Gas line within NYC code?
    Got a quick question. My friend's husband thinks he knows everything so I"m watching his progress on his kitchen. He switched around the fridge and the stove but failed to move the gas line. Its only about a 3 foot move away from the original gas pipe. But what he did was put a cabinet where the gas line is located. Therefore you have to drill a hole through the cabinet to connect the gas pipe. Is that within code? Illegal to do? I've never seen that before. I don't even want to get into the plumbing yet. I'll have to take pictures to show you this nightmare. But one at a time first
    Plumber jimbo's Avatar
    Out here, as long as you have access to the shutoff valve, and the flex line is not too long, it would be legal.
    Default gas
    The length of the gas flex line would determine whether it is legal or not.
    DIY Senior Member TedL's Avatar
    Sep 2006
    NY Capital District
    NYC tends to have the strictest codes imaginable. Not sure they even allow flex at all.
    How do you install a typical gas stove without at least a short flex? Tear out the cabinets? Put a hole in the wall?
    Sep 2006
    NY Capital District
    Just checked it, and flex is allowed for appliances other than water and space heaters.
