Results 1 to 8 of 8
Thread: Anyone use a Watts 80 ballcock thermal expansion valve?
    DIY Junior Member imac567's Avatar
    Dec 2012
    Southeast NC
    Default Anyone use a Watts 80 ballcock thermal expansion valve?
    As an alternative to an expansion tank the Watts 80 is recommended for pressure relief when connected to a closed system (county or city water). Anyone use one? Do they work and how reliable are they? Thank you.
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    They waste water and fail, wasting even more water.
    Best choice to control thermal expansion is a potable water expansion tank pre charged properly at the water heater inlet.
    If Payback is so important to you, why are you not driving a Toyota Corolla?
    FWIW, a properly operating expansion tank does not waste water, a pressure relief valve will. An ET helps to maintain a more even pressure, an relief valve only puts a top limit on it, not hold it to a more proper level. A relief valve may be a good backup, but they can fail as can an ET, then you have nothing to prevent overpressure and potential leaks. Personally, I would not use one as my primary closed system solution.
    Yakima WA
    There a very old, shop worn saying, "If is ain't broke, don't fix it". I think that applies very well to this question. A thermal expansion tank works very well, does not waste water, is easily replaces when it fails, and is inexpensive. Why go look for an alternative?
    Dec 2012
    Southeast NC
    I see your points, all of them... I'm looking at an Amtrol ST-5 2 gallon, looks good because I really wanted a lined tank, for corrosion reasons. If anyone knows of a better one, Please let me know. Thank you. By the way is there a certain distance it has to be installed from the hot water heater? I'd like it to be in my outside pump room just after the pressure regulator.
    It can be installed anywhere on the cold supply side after the PRV. But, there should be no shutoff valve between the WH and the new expansion tank. This is to ensure it can do its thing when the WH starts to run. They don't last forever, but do last a number of years. Adjust the precharge to your static water pressure before installation.
    Dec 2012
    Southeast NC
    PRV? Pressure Regulating Valve?
    Quote Originally Posted by imac567 View Post
    Pressure reduction valve or whatever is causing your system to be a closed system (could be a check valve).
    There should be no valve between the ET and the WH.
  1. Leaky Valve and Thermal Expansion Tanks
    By leakylarry in forum Water Heater Forum, Tanks
    Last Post: 03-09-2011, 09:15 AM
  2. Help Please, Thermal Expansion Control Valve
    By rhumbaclave in forum Water Heater Forum, Tanks
    Last Post: 11-16-2009, 06:54 AM
  3. Thermal Expantion Tank vs Thermal Expansion Relief Valve?
    By Grayfeathers in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-07-2009, 10:08 PM
  4. Watts Expansion Tank
    By USAFRet in forum Water Heater Forum, Tanks
    Last Post: 04-18-2009, 06:39 AM
  5. Best location for Thermal Expansion Tank and Pressure Reducing valve?
    By bobwood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2008, 07:15 PM
