Results 1 to 2 of 2
Thread: Jetted Tubs, some jets don't work
    Default Jetted Tubs, some jets don't work
    Hi All, I have inherited a Jetted bathtub (brand unknown). The first two jets work fine the last four donít project any/much water. My question is can I clean this blockage (if that is what it is..) with a liquid drain type cleaner Ė Iím thinking not because that would be a big ďNo NoĒ for the pump. Basically I want to fix it the easiest way in one trip. I donít think a typical cleaning with cascade and bleach is going to free up these jets, and I donít want to drive over to the house and pull the skirt and then find out I need to run to the hardware store to get ďXĒ. Any trouble shooting suggestions would be greatly appreciated. Thanks, Dean
    Default Resolved
    Hi All. I feel so stupid. I totally filled the tub to try cleaning it with cascade detergent and a little bleach and all the jets worked fine. It seams that if you don't have plenty of water then some of the jets will not work as expected even though they are below the water line... Argh!
