Originally Posted by
pitteach
Thanks for the reply Dana. This is in fact a sealed combustion model with separate intake and exhaust lines. The previous "chimney" was a chase through the center of the house with a double wall pipe. I am replacing the hwt with a RUUD power vent system to eliminate the metal piping which seems to have charred the chase structure over the years. I am contemplating whether to run vent and intake lines back through the old chase and out the roof or out the side of the house. Both have pros and cons. As for the condensate, I will be using sump pump to remove the water.
I have installed many of these types of furnaces, but they have always been single stage units. This particular furnace runs 12 minutes @ 65k btu and then calls for high heat @ 92k after that if needed. If I were to put in a single stage 80k btu, it would run at a constant 73k. My thought is that the low heat on the 2 stage would be enough to heat the home without calling for high heat on those days that are not as cold, and on the exceptionally cold days, the high heat will be used. I believe that the low heat scenario would make the furnace cycle longer, but less often?
