Page 1 of 4 1234 LastLast
Results 1 to 15 of 49
Thread: Sometimes you just gotta make it work...
    Homeowner jfls45's Avatar
    Jun 2009
    I live in PA
    Default Sometimes you just gotta make it work...
    Plumb a shower drain into a floor drain that goes into a gray water system. Cutting that terracotta pipe was pretty hard. I tried using a carbide blade on my reciprocating saw with not much progress. I ended up notching the pipe with the air chisel and smoothing it out with a grinding wheel.
    (I ran water using the garden hose into the p-trap for awhile without any problems before I poured the concrete.)
    See attached pics
    And this is why Chrysler is in trouble.
    Sometimes you need to retool and bring in the good machinery if you're going to compete.
    A man is only as good as his tools.
    I applaud your enthusiasm for the job.
    Nov 2008
    Chicago, IL
    *sheds a tear*
    I am sorry.. I failed you. I do pray what you done works for you many years.
    Jun 2009
    Penticton, BC
    The biggest problem you're gonna is having saturation the rock pit and clogging it up with hair over a # of years.
    Other then that I don't see why it won't work.
    You're also gonna be getting some lovely gross smells coming outta the shower drain once you dump some warm water and bacteria into that rock pit because you have no trap on your shower.
    Good work though!
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    Actually he does have a trap -
    Jun 2009
    Penticton, BC
    Quote Originally Posted by SteveW View Post
    Oh sorry my bad! It was hard to see in the picture but I looked closer and yep there it is!
    DIY Senior Member seaofnames's Avatar
    Jan 2009
    Mission, BC
    I hope you have a filter system for that gray water if you are using it to water your veggie garden!!
    Jun 2009
    I live in PA
    Why do you say there is no trap, didn't you see the pictures?
    Quote Originally Posted by Doherty Plumbing View Post
    Good work though!
    Jun 2009
    I live in PA
    I think the gray water pipes into the outlet side of the septic that runs downhill into a leach field. I do know the washer drains into this same system.
    Quote Originally Posted by seaofnames View Post
    Jan 2009
    Mission, BC
    Quote Originally Posted by jfls45 View Post
    Sounds better than some of the people I've read about on here. Nothing wrong with just bypassing the septic tank.
    I'd still be a tiny bit worried about all of the soap and such getting into the soil.
    Jun 2009
    I live in PA
    The grass over the leachfield is lush green and grows fast.
    Jun 2009
    I live in PA
    Default Heres a thought
    Thinking about what you just said, would you rather have pee and poop percolating down into the ground or old soapy water?
    Maybe the two offset each other...
    Jun 2009
    I live in PA
    Default This is my occupation...
    I think I will stick to this... The plumbing work is hard work, my hats off to you guys.
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    So that 1 1/2, unvented? trap and drain runs into what?
    IPC Appendix C - Grey Water Recycling.
    You can't just drain showers or whatever into a cesspit or for that matter on the ground. People have a nasty habit of pissing in showers.
    Jun 2009
    I live in PA
    Deleted deleted
