Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: American Standard Champion Opinion and Issue
  1. #16
    DIY Senior Member Cal's Avatar
    May 2005
    Northern Virginia
    Whoops !! Sorry ,it's
    www.vitra-usa.com
  2. #17
    Quote Originally Posted by jluksic
    Terry and All,
    I reinstalled the bowl to tank - with your recommendations NOT to use a metal washer between the bolt head and rubber washer.
    PERFECT, no leak, 100% water tight.
    The solution above seems counterintuitive but results don't lie.
    Without the washer, you have this: Bottom side of rubber seals against porcelain; top side of washer seals against bolt head. Results: NO path for water to get out!
    Now, add the washer under the bolt head: Rubber still seals against porcelain; top of rubber seals against metal washer. BUT, nothing seals between bottom of bolt head and top of washer. Water seeps through. [In theory you could tighten enough to make a metal-to-metal seal. But with soft rubber and porcelain invloved, there is no way to make this that tight. Not even close.]
