Which suburb? Lots of Cook county burbs want cast iron under the slab still.
hello, gents. another FNG here. i was referred by CX @ the john bridge tile forums.
i have a 13 year old condo. 1st floor, 4" slab. i tore out the fiberglass shower stall. i am putting in all tile. i want to use kerdi & kerdi drain.
i need to know what to do with my trap. it is cast iron, with rubber seals. condition looks solid.
i cannot take out any more than what you see. the pipe goes towards the inground a/c lines for my corner of the building, 3 floors. it would be great if i didn't have to take anything out. but i want to do the right thing.
i don't know what "code" is. i am in suburban cook county.
should i replace the trap with pvc ? or just adapt the kerdi drain to what i have shown ?
thanx you so much![]()
Ron Hasil Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning
Sump and Ejector Pumps | Backflow RPZ Testing
pm sent.
i am figuring that it is code. as the builder "cheaped out" in so many ways. and CI is much more expensive.
Last time I done work in your part of the area, I was required to use cast iron still. Personally I would just call the building department and ask for the plumbing inspector, and ask him what the requirements are. Another way to find out with out calling is head to the local library. Ask for the building and plumbing codes amendments for your town and give it a read. Illinois requires all libraries to carry the local code and amendments to the code.
thanx, Ron. i am just going to leave it. i am not a betting man. but i would bet that it is code.
oh, another question.
can i use the kerdi drain, with a few inch long piece of pvc, down to the CI ?
i don't want to violate code.
The kerdi drain and the short piece of PVC going into the CI trap should be just fine.
thanx...........
