Thread: Connecting to Cast Iron P-Trap
    DIY Junior Member gransom's Avatar
    Jul 2009
    Texas
    Default Connecting to Cast Iron P-Trap
    I am replacing a tub, a picture of the P-trap is below. A 1.5" pvc pipe was inserted into the hole. What is the correct way to fit the waste and overflow pipe into this existing hub? There is not enough pipe coming out of the hub to attach an adapter.
    Jul 2008
    S. Maine
    You need one of these.
    Default drain
    The correct way is to remove the lead, remove the pipe stub, insert a new pipe stub of the proper length, and then repour the lead joint. Assuming it is in the proper location for the new fixture.
