The secondary drain should only have flow if the primary drain is backed up or blocked. All of the manufacturer's instructions call for a trap on the line that I've seen. Under ideal situations, you'd notice when there was discharge from the secondary and have it trigger some alert so you could figure out what's wrong.
You really want something like 1/4" per foot slope from the output of the trap you need to install.
