Thread: Will a nicked copper pipe ever leak?
    Default Will a nicked copper pipe ever leak?
    Hello,
    If one were to nick the hot water copper pipe with a hand saw while removing the surrounding stud, and it does not leak now, does that mean forever no leak?
    Doug
    I ain't no plumber, but I wouldn't bet on it-depending on the size of the nick, of course.
    I would [at least] put a pipe repair band on it as a precaution before sealing the wall back up.
    YMMV
    Quote Originally Posted by yakman View Post
    Hello,
    Doug
    pipe repair band? Hadn't seen one of those before. Google search found a 1/2" x 3" stainless steel band with a neoprene liner and tightening bolt attached to it. Is this what you're talking about?
    I suppose the neoprene sleeve would support the nicked wall.
    The best way to solve this is probably to cut on the nicked surface and couple right there with a soldered joint.
    Is a nicked no leak pipe stronger than a coupled soldered pipe?
    Doug
    Feb 2005
    Talking patch it with solder
    you can cut it if you so wish and put a sharkbite or coupling
    in the line
    One easy way is to
    drain the pipes and simply put a patch of
    solder over nick in the pipe
    you can actually repair a frozen split copper pipe
    bending it back together and soldering it shut....
    so it is no big deal to just put a thick layer of solder
    over the place you are worried about...
