Results 1 to 15 of 28
Thread: Greenish sludgy stuff in water heater tank
Hybrid View
    Default Greenish sludgy stuff in water heater tank
    Hi all, Great forum, lot's of knowledgeble info floating around. It has helped me a great deal in my homeowner maintenance quests.
    Well, today I drained the tank to replace the gas control valve. While I had the tank drained, I decided to replace the anode rod. Of course, I shut off the natural gas, water supply, and electric before I got started.
    After draining the water tank, I removed the anode rod. All that was left was a bare wire. Glad I decided to check it.
    After removing the gas valve, which also threads into the tank for the thermistor, I noticed quite a bit of greenish sludge in the tank. It had the consistency of whipped cream, light and flluffy. There appears to be quite a lot of it in the tank. It even was all over the thermistor probe.
    What's is this stuff and how do I remove it?
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Sounds like sediment. Most times it is not rock hard material but soft and almost slimy. Bluish green color. Need to flush the tank.
    I just post cuz I like to see my avatar.
    Thanks, A Wet-N-Dry Vacuum and numerous flushes pretty much cleaned it out.
    After cleaning, I aimed a flashlight down the anode-rod-hole to illuminate the bottom of the tank as I looked in through hole at the bottom. Lo and behold, the old anode rod (or what was left of it) is lying on the bottom. I guess it dislodged from the wire-core as it aged. I tried to remove it but it was too difficult, (since I was working through the 1" hole)
    Is this old anode rod ok to just lie on the bottom of the tank? I hope so.
    Anyway, I installed the gas valve/thermostat, the new anode rod, and re-installed the blower. Reconnected the gas line, turned on the gas, and did a few snoop checks. Everything checked out, and I'm back in business.
    Aug 2008
    One of these might have done the trick:
    Good luck to ya.
    Default stuff
    That sounds like what an old anode rod looks like before it becomes a bare wire. You probably scraped it off while removing the anode rod. A gas heater control does not have a thermistor, it has an Invar rod. But if you went to the trouble of completely disassembling the water heater, you would have been better off just replacing it.
    Feb 2005
    Talking funky--- nasty stuff
    I have seen lots of the stuff you are talking about...
    I have always wondered about it...
    considering that this sludge has to boil and bubble to be able to heat the water....it sort of makes a stew.....
    it makes me wonder if these sediments or heavy metals
    that boil in the bottom of the heater could cause different skin diseases????
