pump would'nt cut off.replaced water tank,pressure switch,and gauge.pressure holds at 35psi and won't reach the cut off.can adjust pressure switch,but pressure still won't rise above 35psi and pressure is weak like that.water almost stops running before pump turns on.it is a submersible pump.how do i get pressure to go back up to 50psi like it should?
