jphelps
I recently installed a new Kohler cast iron tub and while checking it for level I found that it slopes slightly away from the drain. The slope is very slight, the tub drains correctly, and there is no movement of the tub in any direction. My question is, how important is it to have the tub absolutely level?
Also, the tub flange does not touch all of the studs on the surrounding walls, is this an issue?
