Results 1 to 8 of 8
Thread: No Hot water from shower - Single handle knob
    Question No Hot water from shower - Single handle knob
    Hello,
    In our secondary bathroom, our shower/tub has a single handle knob and when turned to HOT no hot water comes out at all and it just shuts off the water (it drips just a little bit when on full HOT, and that water is also NOT HOT). It is a condo unit and it used to work just fine and this particular shower has seen very little and infrequent use. All other faucets work perfectly fine in the condo.
    What do you think the problem is and how can I fix it myself? Thank you for any and all help!
    -Mike
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    Its the balancing spool and yes you can replace it if you are reasonably mechanicly inclined. Part number RP19804
    http://www.deltafaucet.com/parts/details/RP19804.html
    Quote Originally Posted by winslow View Post
    Is this located right behind the circular plate behind the handle? How do I get to the balancing spool?
    Thanks for your help!
    Yakima WA
    Do you have a plumbing shop in your area that deals with DIYers? These guys are knowledgeable about the products and are very willing and able to show you what to do. You may occasionally find a "smock man" that can do this, but usually at a Box store you just find sales people. Actually, once the cover plate is removed, you should be able to pretty well figure out what to do next.
    Not sure if there are any plumbing shops in my area for DIY'ers, but I could look into that. My next question is, do you have any tips on how to remove the circular plate without damaging the shower wall? It appears that the outside edge (all around) is sealed al to the shower wall with some calking or something similar. Forgive me for the cautious newbie question .
    Jun 2009
    Penticton, BC
    Quote Originally Posted by Mawk View Post
    Take a sharp razor knife and gently cut around the silicone at an angle so that the blade is cutting in towards the valve under the plate. This way you'll avoid damaging the surround.
    Dec 2007
    You may find it very easy to turn a small job into a big one...
    There is a nut that holds the cartridge in that if it is hard to remove and you twist too hard you can ruin the valve.
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Yes, yes you can...
    I just post cuz I like to see my avatar.
