Verify the maximum wattage with that lense covering. If you are not exceeding it, it should be okay. The fixture has a thermostat in it that will shut off the lamp power if it gets too hot. Course, you are dependent on that working properly. IC-AT units are supposed to be okay when covered up with insulation.
