Acrylic you have more options...size, air , whirlpool...
Enamelled steel is cheaper but you limited on size.
What is the best replacement tub porcolien or fiberglass? I have a whole in mine & do not want to do a fix.
Enameled steel tubs are ONLY used because they are cheap. If he has a hole in his tub, it is probably an enameled steel one. Cast iron, and compostites such as Ameriglas, would be the first choices. Enameled steel is not even a close comparison.
